Hello! I am trying run incompressible simulations for a NACA 0012 airfoil at a variety of angles of attack at a speed of 15 m/s. My goal is to see how lift and drag coefficients change with angle of attack.
Here are the links to my project:
Part 1 (AOA = 0, 8, 16 degrees)
Part 2 (AOA = 24, 32 degrees)
From the force coefficients plots for each run, these are the results I have gotten:
However, these results do not make sense because the critical angle of attack should be somewhere around 16 degrees, so the lift coefficient should not keep increasing. Additionally, drag is supposed to increase with angle of attack, not decrease.
Could someone please help me figure out what I am doing wrong? Also, I would appreciate if you could explain things simply because I am just in high school and completely brand new to CFD ! ![]()
