I am trying to upload a 65MB SAT file that was converted in revit. Initially, the upload starts with no problems but at 80%, it gets stuck. After a few minutes, the window closes and no failure messages or anything appears.
If I upload a file that is 100kb in size, I experience no issues at all.
Can you share the file with me please? Feel free to post the file link here or send it privately to me. I will try it by myself and if it does not work we should convert the file.
Does not work for me either. Is there a way for you to export this to a STEP or STL file? That are the most common ones used on the platform and work very well. Alternatives are:
BREP (*.BREP / *.brep)
Soliworks (*.SLDPRT, *SLDASM)
Autodesk Inventor (*.3ds, *.iam)
Parasolid (*.x_t)
Rhino (*.3DM)
Other than that, is there a way to simplify your model a bit? I saw that it has over 4,500 components which is enormous (at least for me). Also what kind of simulation are you trying to perform?
Let me see if I can convert them to any of these listed file formats.
Its a 5 story building with MUAs. I was thinking if to have temperature profile in the building due to the airflow from MUAs.
you’re welcome! I would first focus on simplifying the model before just converting it as the model is insanely big. I am sure you can merge components to a bigger one and just build it out of surfaces.
