I used Ansys 18 in my college which had entirely different user interface with what I am getting now in the official ansys site. I have no experience with simscale but, somehow i managed to correct a few errors that I was getting in my work. Now that I have tried a lot to get through this " Maximum number of iterations exceeded", I still get this. Could you look at my project and tell me where I am going wrong?
My project : SimScale
Thank you
Hi there and welcome to SimScale!
Can you have a look at this doc entry: Error: Maximum Number of Iterations Exceeded | SimScale - please let us know if that helped. Also note that compressible flow simulations are quite sensitive to settings let alone the mesh. CFD Squad, feel free to jump in here!
Already done settings according to this document, still getting the same error. I need someone to look at my settings and tell me what is worng.
Thank you
@reemoh The mesh for the analysis is very fine and has 20.9M cells and 11.3M nodes. Despite being a symmetry model, which is good to simplify things, you also need to factor in the time it will need to solve those may meshed cells and nodes. As such, it will require quite some runtime. First my suggestion will be that the setting in your simulation control needs to be edited. ![]()
The error message which will show up on the Event Log states: “Maximum number of iterations exceeded.” ![]()
My suggestion is that you check the values for the Endtime, change it by increasing it from 100s to 1000s or even 3000s. Then you can increase the value of Delta t to 0.5s. Next, increase the maximum runtime from 10000s, 14400s to 100000s- and the higher the better.
You can also check the Solver Log, and read towards the end: " [10] Writing old times: [10] 1 times to write [10] Write t=1 to “processor10/1” [10] Current time not written.Set ‘writeCurrent true’ if you want that (but it may cause segfaults) [10] Reraising original signal [1] [1] [1] –> FOAM FATAL ERROR:
[1] Maximum number of iterations exceeded [1] [1] From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const
[1] in file at line 99. [1] FOAM parallel run aborting"
My point is that it is a setting issh with the timesteps
