Hi there, I am very new to simscale and wish to use the platform to investigate the aerodynamic benefits of tapering and adding a helical form, with the CAARC building being my reference model.
I have copied the CAARC simulation conducted by @dlynch , importing a sample geometry into the model.
Once imported I try to apply the the surface mesh to the model with the same resolution as that of the simulation I copied, however a message regarding the number of buffer cells appears, suggesting the value be increased to 3 or greater. Once i do this an error regarding the geometry primitives appears (see image)
Any help with fixing the issue as well as help regarding this project would be greatly appreciated.
See model here: CAARC trial with 30deg helix k-w SST by ss02150 | SimScale
Hello!
This simulation was crated using the Incompressible LBM solver, which is not available for community or academic program accounts.
In order to run your simulation, please create a new simulation using the Incompressible CFD anlaysis type, and create the traditional setup for external aerodynamics:
- Create a Flow Region
- Delete the building part
- Assign the flow region as domain
- Assign boundary conditions
- Create mesh refinements
- Add the Forces and Moments result control items
Hi there thank you for you help, in terms of the model, would it be possible to just use the existing set up and change the analysis type to k-omega SST. If so would the results greatly differ from that of the k-omega SST(IDDES)?
@ggiraldof
Hi again!
I am afraid that you have to create a whole new setup when you change the simulation type.
To help you, I did this simulation template which you can modify and use to kick-up your studies:
Here I used the k-omega SST model implemented in our solver. I am not sure how it compares with the method you mention, but under good circumstances (good mesh, boundary conditions and convergence), all methods should give close results.
Hi @ggiraldof,
Thank you for providing me with this template, I really appreciate you taking the time to set this up and provide me with the helping hand with my project.
Kind regards
Sam
