Building Meshing Issues
Hi everyone,
Currently trying to mesh a building geometry.
I had similar meshes before, but those kinda worked. This time its a similar geometry but with some notable changes.
  • Much much larger bounding box, 1km square
  • Specific surface refinement, specifically at the 4th Floor with a level of 4 and 5, others at level 2 and 3.
  • Customized Bounding Box Geometry Primitives. I believe this might be the key issue, I aimed to get each bounding box cell to be a square in all the sides and 1m by 1m.
The meshing process basically gives me an error and I’m not sure exactly how to proceed.
Hope to get a reply soon!
Hi @Get_Barried, just checking is it mesh 5 that is the issue?
Kind regards,
Darren
Sorry Darren I forgot to clarify. Its Mesh 4.
I pressed run then realised the possible error and killed it.
the mesh size is 1090x1096x300 = 358 million cells in the base mesh without any refinement. With refinement levels of 4 in places, we could be approaching 1 billion cells. Flow in the non-important mesh should be kept as coarse as possible, I think it is reasonable to use a 100x100x30 in the base mesh but feel free to but a lvl 2 refinement region around the building.
Hope this gets you straight,
Darren
Yeah I kinda suspected that was the issue :stuck_out_tongue:
I’ll try it out with a lower mesh size. Thanks Darren.
