Boundary Layer Does Not Form - Except When Default Settings Used
That sounds very smart! I guess what you are saying is to combine 2 STL files, each with 1 of the Solids…
Ok, I just need to find out how to do that as I am not familiar with the process you mentioned. But thanks!
Edit:
  • awesome. previously i was saving as binary so the file was not readable. but i saw the ascii option and that is readable (in notepad++)
  • so i did as i think you meant, i appended one file (with one solid) to the other (with the other solid) and renamed them
  • i checked them in Fusion and I do see 2 bodies
  • I imported them into SimScale - it was one solid but 2 i-dont-know-what (faces?) that i was able to select for meshing based on mrf and propeller. it’s meshing now… so fingers crossed. still, great hack! will update if it works.
