Yes it helps thank you!
Though many confusing points
I think I am ok on a IBM simulation which allow fluids and solids.
Also that i don’t do a “negative of the devices” cut from the air flow box otherwise i can’t specify iron material /vs the flow box.
But
if i don’t put a boundary, the boundary dot stays red and the simulation tells :
- Temperature field does not have a reference level because there is no fixed temperature boundary condition. Please provide at least one boundary condition where the temperature is fixed or consider using natural convection inlet/outlet boundary condition for natural convection cases.
If i put the boundary with the flow box and natural convection, some faces are not recognized …
For the temperature : I set initial conditions 20 degres + 2 subdomains for the two irons pieces: 20 and 80 degres.
This set up is confusing because anyway the system says needing the boundary for ambient temperatures so it is redondant.
Maybe not needed:
The IBM propose a cartesian shape for the flow box but maybe it is not needed as there is a flow box.
Also the option for passive scalar talked about in the tutorial you kindly sent me doesn’t appear in my initial conditions.
As well the contacts set up might be not needed, as they are supposed to be done automatically.
The set up as it is now doesnt go further than 5%, tried 3 times. Couple for few hours with no progress…![]()
