I’m setting up a conjugate heat transfer (CHT) simulation of a tightly packed prismatic battery module and running into the classic trade-off between mesh count and resolving the thin fluid gaps between cells and the solid-fluid interface.
A few points I’d be interested to hear the community’s experience on:
For the thin coolant channels between cells, are you getting reliable interface temperatures with prism/inflation layers plus a trimmed mesh, or has it been worth switching to a different meshing approach?
How many inflation layers (and what y+ target) have worked well for you at the cell-coolant interface before peak temperature stops shifting?
For transient duty-cycle runs rather than steady state, how are you balancing timestep size against mesh fidelity to keep solve times reasonable?
Anyone including busbar joule heating in the same model, or decoupling it as a separate step?
I generally run a mesh independence study tracking peak cell temperature until it plateaus, but I’d like to hear how others approach the same problem — especially what gave the best accuracy-vs-cost balance in practice.
