Best Practices for Meshing in Drone Propeller Airflow Simulations
Thanks for all the feedback — it makes much more sense now.
I have two quick follow-up questions:
  1. Is there a way to export a static, high-resolution image of the mesh cut (for example, a cross-section) to use in a report?
  2. Regarding mesh independence: When I run my sensitivity study, what’s the best way to determine whether my simulation results are mesh independent?
Let’s say I’ve already applied a first mesh refinement (I called it “medium”). I assume I would go into the result controls and check whether the parameter of interest (in my case, velocity) changes only marginally despite an increase in mesh cell count. Is that the correct approach? Could you please clarify the best practice for this step?
