Applying transient surface heat flux to an annular brake-pad contact region without partitioning the CAD
Hi everyone,
I’m working on a transient thermal simulation of a Formula Student brake disc in SimScale.
The disc geometry is already imported, but its friction faces are continuous and have not been partitioned into separate annular brake-pad contact regions.
I need to apply surface heat flux only to the annular track swept by the brake pads, rather than to the entire friction face.
I understand that SimScale supports coordinate-dependent heat-flux formulas. Is it possible to use a conditional formula or constrained region to restrict the applied heat flux to a specified radial range on the existing face, without modifying or reimporting the CAD?
The disc lies in the XY plane, with its rotation axis along Z. If this is possible, could someone explain how to define the constrained region and the appropriate formula in the current SimScale interface?
If not, is partitioning the friction faces in CAD the recommended approach?
Thank you!
hi,
you can restrict the heat flux radially using a coordinate-dependent formula, but partitioning the faces is highly recommended for thermal accuracy.
The Formula Approach Since your disc is in the XY plane rotating around the Z-axis, you can define the heat flux using a boolean multiplier based on the radius. In the surface heat flux value field, switch to the formula input and use a structure like: (X^2 + Y^2 >= r_in^2) * (X^2 + Y^2 <= r_out^2) * Flux_Value. Replace r_in, r_out, and Flux_Value with your actual numbers. This evaluates to 1 inside the annular track and 0 everywhere else on the continuous face.
The CAD Partitioning Advantage While the formula restricts the input mathematically, the solver’s accuracy heavily relies on the mesh. If the face remains continuous, the mesher cannot align element edges specifically with your thermal boundary. This usually smears the temperature gradients across the disc unless the entire continuous face is meshed with extremely fine elements.
In-Platform Splitting You do not actually need to modify your native CAD and reimport it. You can jump into SimScale’s CAD Edit Mode, generate a primitive cylinder matching your brake pad track dimensions, and use the Split or Boolean operations to partition the friction face directly in the cloud.
Thank you ! yes i continued with the formula approach .
