How to apply torque on shaft?
Hi @daniel11,
you can have a look at this project: Static Analysis of a Shaft under a Torque load
For general information about Boundary conditions in Solid Mechanics, pleae have a look at:
Solid Mechanics - Boundary Conditions
If you need anything else, please let me know.
Hi
I made 2 examples, and I got error in running.
I try to apply a torque and fix on 2 tube planes.
Whats the problem?
Hi @daniel11,
you would have to set e_x & e_y to zero and e_z to 1 since you are turning around the z-axis (“Right-hand rule”).
Let me know how it goes.
P.S.: Sent you a link with a small modification in your model.
The torque mNm is [Nm] or [mili Nm] ?
It is Nm
The m might be a little bit irritating here but refers to “moment”
