I am running a small test for learning purposes where I want to imply internal heat conduction inside a cuboid volume, I tried using the convective heat transfer and the conjucate heat transfer v2.0 and I cannot yet tell which analysis is more suitable for my problem (which is a 2D heat conduction problem to be specific) and I also cannot tell which boundary condition I should use to imply the internal heat conduction in my problem.
Hi @BelalAyman,
Thanks for posting your question.
SimScale just allows the user to make 3D simulations. As you said above, once it is a heat conduction problem, so Conjugate Heat transfer should be the right choice. Could you please post your project link here just to make us sure about it?
best,
