Aortic Valve simulation
  • A description of the project and what you are trying to achieve
    I have an aortic valve and I want to run a CFD simulation and find out the stress on the leaflets of the valve. Using blood as the fluid. Kindly find screenshots attached.
L
ink for project (Aortic Valve) - https://www.simscale.com/workbench/? pid=7079222126942465424&mi=run%3A21%2Csimulation%3A19&mt=SIMULATION_RUN
Hi there, thank you for using the forum!
To begin with, I suggest you use STEP or Parasolid format instead of STL - this is not a suitable format for any analysis type except from the LBM -.
Regarding this specific case, shouldn’t the fluid flow through the valve? For this , you will have to include the flow region in the CAD model. For example, the first out of the two models inside your project, named as ‘Pipe Junction Model’, represents the fluid.
