Angular velocity as in a spinning blade. Inertia loading. Is it possible with SimScale?
Thank you,
Scott
Thank you,
Scott
I usually put the spinning geometry in a rotating zone and leave the fluid domain doing whatever. I think this is the most straightforward setup. If you are happy sharing your geometry there might be other solutions to consider.
Kind regards,
Darren
edit: I did not pay attention to ‘not CFD’ I’ll let someone more FEA orientated take this
HI @srichardson,
I think a centrifugal force loading condition and a nonlinear analysis should accomplish what you want.
If you can provide more details about your problem we can provide a more detailed answer based on your problem.
Good luck!
Christopher
