An error occured
I have a problem with generating a mesh.
Project: Nageli henge measuremenets by jjansman | SimScale
Simulation: “25m, 2.2m:5m/sec,ap=8.5, F=7.5, test=Extrusion”
Mesh 11 → Refinements
“Volume custon sizing” (0.1m,0m)
Generate
A mesh is generated successfully, also a Simulation in works.
I changed the “Volume custom sizing” to “Extrusion mesh refinements” (as I wanted to test that feature)
Delete: “Volume custom sizing”
“Extrusion mesh refinements” (0.08m)
Generate
I get this error message:
Mesh operation failed
The following mesh operation(s) failed:
    Mesh 11
        An error occurred. Learn more.
Please check the 'Event Log' and 'Meshing log' for more details. In case of questions, please reach out to support or ask in the forum.
The link provided under 'Learn more" (Fatal IO Error: An Error Occurred | SimScale Knowledge Base ) doe snot really help, so that is why I ask it here.
Can you help? Thanks.
All the best
Hey @jjansman,
“An error occured” is always a bug. Thanks for letting us know. I have reported it to the team already.
We will let you know here once there is an update on the same.
Satvik
