Aerodynamic drag analysis of a 3D wing profile at high speed (80 m/s). Checking mesh quality and result validity
Hi everyone,
I am simulating the aerodynamic drag of a 3D wing profile and I would highly appreciate it if someone could review my project setup and results to tell me if they are realistic and objective.
Model & Setup Details:
  • Wing dimensions: Span 1m, Chord 60mm, Thickness 6mm.
  • Flow speed: 80 m/s (approx. 288 km/h).
  • Physics setup: Incompressible, Steady-state, k-omega SST model (End time: 1000s, Delta t: 1s).
  • Mesh details: 6 million cells. I used a smaller External Flow Volume, a Cartesian box for region refinement, and a manual surface refinement on the wing.
  • Note: I received a minor warning about mesh quality metrics outside recommended ranges, but visually the mesh and the profile shape look perfect and not deformed.
Simulation Results:
The simulation achieved excellent convergence with a perfectly flat force plot at the end of the 1000 iterations. The extracted forces at 80 m/s are:
  • Total Drag: 3.2 N
  • Pressure Force: 1.2 N
  • Viscous Force: 2.1 N
Why I am asking for a review:
In my previous attempt with a much coarser mesh (around 350k cells), the automatic mesh settings deformed the fine geometry into a simple wedge/triangle shape. That faulty run yielded a Total Drag of 6.0 N (Pressure: 4.0 N, Viscous: 2.0 N).
After refining the mesh to 6M cells to capture the perfect aerodynamic profile, the Pressure Force dropped significantly from 4.0 N to 1.2 N, cutting the total drag almost in half.
My questions for the community:
  1. Given that the viscous force is dominant (approx. 64% of total drag) and the force plot is completely stable, do these values (3.2 N total drag at 80 m/s) look objective and realistic for a wing of this size?
  2. Is a 6M cell mesh sufficient for this Reynolds number, or should I refine the boundary layers even further to ensure the y⁺ values are optimal?
Here is the link to my public project: https://www.simscale.com/workbench/?pid=2004101406667325192&location=mesh:45b53e6a-7655-4762-8bae-2ad486b0cc4f&hostSimulationSpecId=d78467f5-9207-4086-96d2-b81a82a533b2
Thank you very much for your time and guidance! Jan
Hi @honzanovak,
Your total drag value of 3.2 N looks physically realistic for this setup, but your mesh distribution needs adjustment to make that 6M cell count work efficiently.
Aerodynamic Forces Even perfectly symmetrical airfoils generate drag at zero angle of attack due to skin friction (viscous force) and wake displacement (pressure force). The fact that your viscous drag (2.1 N) is higher than your pressure drag (1.2 N) is exactly what you would expect for a streamlined body at this speed.
Mesh Distribution While your overall control volume size is correct (it needs to be large to prevent boundary blockage), your cell allocation is inefficient:
  • Wasted Cells: The Cartesian refinement box is excessively large. It is eating up millions of cells far away from the airfoil where flow gradients are minimal.
  • Abrupt Transitions: Looking at your cutting plane, the jump from the extremely fine boundary layer cells to the coarse outer tetrahedral mesh is too sharp. This sudden volume change degrades flow gradient calculations.
To optimize this, shrink your Cartesian box to hug the airfoil and its immediate trailing wake much tighter. Use the saved cells to create a smoother volume transition zone right outside the boundary layers.
