hello!
i am trying to do a hydrodynamic analysis to check the reaction of the device to to wave impact. kindly help me with the procedure as i am a beginner.
Hi @anusha!
Please make sure that you post your project link along with a small description of what you want to achieve. I am sure @PowerUsers_CFD and me can help you out with your project.
Cheers and all the best!
Hi @anusha and thanks for the link!
Two questions:
Do you want to perform an external flow analysis to see how the object behaves in multiphase flows?
The dimension of your model is in the order of 10^{-4}. Is that on purpose or do you want to scale it? This is possible via the geometry operation in the Mesh Creator.
If you really want to perform a 6-DOF analysis of your model you can have a look at the following project as an inspiration: Floating Boat - 6 DOF motion
Would be nice if you could give us some more information. The more information the faster we can help you!
Thanks and all the best!
yes, i would like to perform an external flow analysis,
i want to study the motion of the device when placed on the shore and its response to the incident waves
Hey @anusha!
Then the project I posted above should be a good template you can use for your project. If you get stuck somewhere feel free to contact me - will jump in to help you.
i tried the same but i am not able to get the result, there is an error which i am not able to rectify
