Torodial propeller
Hello Samith, I may be wrong, but as far as I know opposite signs on a propeller, rotor or any kind of blade suggests that “it requires power” to sustain the movement, which is your case. If you were designing a turbine, you would expect the signs to be equal, given that the system “takes power” from the medium, instead of “supplying power”
