Hi @jmaurer,
The car doesn’t “disappear”, it’s walls are still present which can be seen if you set the surfaces to translucent:
Keep in mind that the flow region is simply an imaginary volume where the fluid would be contained - so it would be a box including the negative of the car.
Well, there is no need to follow the exact value provided in the tutorial - it’s just a general suggestion so that the boundaries don’t influence the flow near the region of interest (which may very on a case-by-case basis).
