GPL License Simscale
Thank you for the reply, and the work will have SIMSCALE and OF uses, because I came to the forum because I loved that everybody and due to the cloud system with 16 processors available, which helped me a lot (my notebook just have 4 cores), so if I could use it I would be glad to put in the reference.
The problem is that in the first time, in a conversation with my professor, the term paper were done using JUST OF, but I had some problems doing the mesh there and some memory problem due to my limitated computer. Since I came to SIMSCALE I resolved these issued, but this days I tried to do the SAME mesh in OF and it didn’t work.
So, following your answer, could you please tell me something that could help?
  • What versions of OF is used in the Parametric Hex dominant generator? Which is similar to the SnappyHexMesh in OF, which I am using.
  • What is the version of OF used in the simulation process? I am using version 6 and 7 for over a year but I would like to represent the results from here as similar as I can (because I know that were made modification by you here in SIMSCAL, what is great).
  • Is there any possibility that someone in the fórum that knows OF very well to help me doing that: get the mesh as similar as possible from here in SIMSCALE to OF, but without exporting, I want to do there in OF because of the goal of the term paper as I told in the beginning of this message.
So, just to compile the informations: I am using SIMSCALE to hurry up somethings and get help with the users ( and try to help others too), and I will reference in my term paper certainly, but I really have to use OF because there will be others things to do in the work, and for that I will need an open source tool.
And I have invested SO MUCH time doing the mesh (because of the geometry particular, sharp edges and so on), that had to be with parametric (because of the use in SHM in OF), and I really don’t have much time to do all the things again (because of the dead line of the term paper itself), that’s way I am asking for help.
Thank you for the attention, I really appreciate that.
Regards!
