'Z3 C1' simulation project by vijalp19
I created a new simulation project called 'Z3 C1':
CFD anal.
Hi @vijalp19!
Nice project you have here. I saw that the rear of your model has a missing part. Do you think you can fix that?
I can if I rebuild that part of the cad model, unfortunately I do not have the time to do so. The base model (i.e. the car) has numerous issues regarding the geometry so I had to run each lifting component separately. I did not bother with refining mesh because of this so all my results are ballpark estimates or worst case, entirely wrong. I plan on using the official Honda NSX concept cad files for future work
@jousefm If you are interested in anything I’ve done, I’d be glad to share the cad files
#5
Hi @vijalp19,
yeah why not :slight_smile: If you want you can upload your Honda NSX model on SimScale and I will see if it is clean.
If that is the case, we can set up the Meshing & Simulation if you like.
