In the “Post-Processor” view we can select different items in the “Field” drop down to visualize different data. The items are abbreviated such as “U [point-data]”, “alphat [point-data]”, etc. I’m not a physics or CFD expert so I don’t know the meaning of all these fields. Where can I find more information on what these abbreviations stand for?
Hi @tryabin,
Here you have a couple of videos about Post-Processing for CFD and CFD analysis, are very good videos for introduction and also this fields are mentioned on them:
INTRODUCTION TO POST-PROCESSING by @psosnowski
ONLINE POST-PROCESSING WITH SIMSCALE by @psosnowski
CFD WORKSHOP (Turbulence explanation) by @Milad_Mafi
But in general P stands for Pressure of the fluid, U for the velocity of the fluid, k for the turbulence, Omega for turbulence dissipation rate.
Hope this helps you, I encourage you to follow the recorded webinars and workshops from Simscale Youtube Channel so you can get more expertise in CFD (I’m neither a CFD expert but I’m trying to )
Thanks, but I was looking for something along the lines of a simple list that defines what all the abbreviations stand for. I’m particularly interested in the more obscure ones such as “alphat” and “mut”.
Hi @tryabin - we should add such information to our documentation. Thanks for bringing this up. In the meantime, SimScale is using OpenFOAM for all CFD solvers, which has extensive documentation here:
and cfd-online is also a great resource. See here for references to “alphat” and “mut” :
Thanks, I agree it would be helpful if all the possible fields were defined in one place.
