# What to do if geometry does not appear in your Hex-dominant parametric algorithm mesh - try the Feature Trick
**URL:** <https://www.simscale.com/forum/t/what-to-do-if-geometry-does-not-appear-in-your-hex-dominant-parametric-algorithm-mesh-try-the-feature-trick/87330>\
**Category:** Using SimScale\
**Created:** [January 6, 2020, 1:41pm UTC](https://www.simscale.com/forum/t/what-to-do-if-geometry-does-not-appear-in-your-hex-dominant-parametric-algorithm-mesh-try-the-feature-trick/87330 "2020-01-06T13:41:05Z")\
**Showing post:** 6
**Author:** ![DaleKramer](https://www.simscale.com/forum/user_avatar/www.simscale.com/dalekramer/32/20201_2.png) [@DaleKramer](https://www.simscale.com/forum/u/DaleKramer)\
**Post date:** [January 14, 2020, 5:32pm UTC](https://www.simscale.com/forum/t/what-to-do-if-geometry-does-not-appear-in-your-hex-dominant-parametric-algorithm-mesh-try-the-feature-trick/87330/6 "2020-01-14T17:32:45Z")
This issue is much broader than I first imagined…
The Feature Trick even fixed an empty mesh that [nobody could figure out why it remained empty](https://www.simscale.com/forum/t/yaw-simulation-for-a-fsae-car/87395/18) and [here](https://www.simscale.com/forum/t/how-do-i-set-level-0-cell-size-in-hex-dominant-only-for-cfd-meshing-nowadays-or-where-did-base-mesh-box-discretization-go-to/87413/11)…
[Here is that empty mesh result](https://www.simscale.com/workbench/?pid=8865627795022065882&mi=spec%3A8ff45771-a060-4498-b98e-a343be977919%2Cservice%3AMESHING%2Cstrategy%3A191&sh=45):
 ![image](https://www.simscale.com/forum/uploads/default/original/3X/5/1/51bb30e26c5ea6ea051faf902f8e0442bf2c2602.png)
[Here is the mesh when a Feature refinement was added](https://www.simscale.com/workbench/?pid=8865627795022065882&mi=spec%3A38680a7b-50af-4f99-b059-b02e1987a514%2Cservice%3ASIMULATION%2Cstrategy%3A46) at the most refined level of the other mesh refinements:
 ![image](https://www.simscale.com/forum/uploads/default/original/3X/6/b/6b04b2c0ab7ad6f76078a0f722cab241a3beea5d.png)
So, when you have an empty mesh, give the Feature Trick a try 😉
_[View the full topic](https://www.simscale.com/forum/t/what-to-do-if-geometry-does-not-appear-in-your-hex-dominant-parametric-algorithm-mesh-try-the-feature-trick/87330)._
