Velocity field started diverging
hello, can someone help, my project error with " Velocity field started diverging to a value of 1.02682e+07 m/s near the position: (8.839e-1, 4.463e-1, 7.123e-1). Please check the mesh quality near the reported location and try refining the mesh". If i refine all the hollow it will be another problem with the machine ran out of memory. in simulation run 1, its perfectly running, but when the next simulation created i added the absolute power sources than its start error with velocity diverging, is that the reason for the error ‘velocity diverging’? thank you in advice
my project link: https://www.simscale.com/workbench/?pid=5820360356901421049&mi=run%3A62%2Csimulation%3A26&mt=SIMULATION_RUN#
best,
bheatric
Hi, as a starting point, make sure to go through the steps outlined in this article.
