Actually I have completed my simulation and would like to calculate the values of variables such as velocity and pressure at selected data points. How to do it in the Simscale?
Sachin
Sachin
Hi Sachin!
Depending on what you have written out (technically the solver did it but you can decide if you want to have separate result control items…) you can look at the data plot and use the context menu in the upper right corner. This can be helpful if you want to extract fluid flow data and use that as input for a structural analysis for example.
Hope that helps!
