'Valve' simulation project by jgoudy
I created a new simulation project called 'Valve':
Valve Body Flow
Hi jgoudy! I had a look to your geometry and to generate a good mesh, it would be great if you could clean it using a CAD software. I mean, you can work in order to delete those rounds/fillets before you generate the mesh. It helps to have a much better and uniform mesh, reducing with it simulation time and cost. You can use the www.onshape.com platform for it. Good work!
