'Tutorial-01: Connecting rod stress analysis' simulation project by lcrazy
I created a new simulation project called 'Tutorial-01: Connecting rod stress analysis':
Tutorial project for a stress analysis of a connecting rod. The project only provides the geometry to start with. See our tutorials section to have a look at the step-by-step instructions to set up the simulation.
Hey @lcrazy I see you are trying to perform a tutorial. However, you had a failure for the mesh. The reasons are as follows:
  1. You are trying to perform a solid mechanics tutorial.
  2. The mesh type you selected is snappy hex.
  1. This is a wrong mesh type for a solid mechanics simulation.
Suggestions:
  1. For structural analysis SimScale provides the following options for mesh:
  • Fully automatic tetrahedralization
  • Parametrized tetrahedralization
  • Tetrahedral meshing with prismatic viscous layers
  • Tetrahedralization with refinements
  1. I suggest you to use Fully automatic tetrahedralization for the model.
Snappy hex meshing are used for fluid mechanics simulations. If you are interested in them, I suggest you to do the CFD tutorial.
If you have any question, please feel free to ask.
Cheer
Ali
