'Turbine' simulation project by akhm74
I created a new simulation project called 'Turbine':
A test for a internal propeller
Nice one @akhm74!
Did you manage to validate your results?
Hi Jousef
To some degree. Simscale seems pretty able to solve the most common problems.
Have a good one!
Arne
Hi @akhm74!
Sounds good! How big is the error?
I am confident that the result is correct. Just thinking that the torque is smaller than I would expect. But small diameter and slow fluid will not produce high torque. Also blade design could be highly improved.
