'Turbine Blade Analysis' simulation project by dbower
I created a new simulation project called 'Turbine Blade Analysis':
Turbine Blade Analysis - Wind Tunnel Test
As the speed is higher at the tip of the blade, did you consider the speed gradient from center to tip in the simulation ?
Thanks for the answer
