'try it 2' simulation project by jWalsh
I created a new simulation project called 'try it 2':
getting data
Hi @jWalsh - do you need any help with uploading a CAD model?
I tried to import a model from Onshape but never was able to succeed.
Created a project
Opened the project
Selected import from Onshape
New window opened at Dashboard
Selected the project
Import option not available in this window
I verified that Onshape id and SimScale Id’s match and also changed SimScale password to match my Onshape password — no change
Joe
Just to make sure I understand - you mean that this import selection was not possible?
#5
that is correct
#6
indeed the window that you showed with alist of models never appeared - went to SimScale dashboard instead
#7
Hmmm, that’s very odd, might be a syncing issue on our end. Could you try one more time to verify since it’s been a couple of weeks?
#8
not sure when I can get to it but I will try again
