'tests' simulation project by tbacon
I created a new simulation project called 'tests':
tests
@tbacon,
the issue with the meshing is that your CAD model only consists out of faces, no solids. You can check on this in the geometry event log after uploading your model, see here:
Such files can currently not yet be processed by the volume mesher, therefore I’d recommend that you upload it in STEP fromat, where it works smoothly with most CAD systems. I quickly downloaded your model, ran it through my CAD software, exported it as step and uploaded it again. Then meshing + sim was straightforward.
Hope I could help,
David
https://www.simscale.com/projects/dheiny/knife_fea_stress_simulation
