'test1111' simulation project by meminic
I created a new simulation project called 'test1111':
test22222222222222
Hi @meminic,
Your model looks great but I see you are facing problems in meshing. This may be because you have imported a geometry in IGES format. This format has some problems with our platform. Apparently, the model doesn’t have any solids, and therefore, Simscale has problems with meshing the geometry.
Also, your bounding box seems very big, see the image below. You can use scaling operations to bring it to correct size.
I copied your project and converted it to an STEP format and I found some strange surfaces
I have cleaned your geometry and meshed it for you. Please find the link of the project below
https://www.simscale.com/projects/nava/test1111/
Happy Simulating!
Navaneeth
