'test1' simulation project by davidschiffmann
I created a new simulation project called 'test1':
this is a test
@davidschiffmann,
I had a quick look at your model. The reason for the volume mesher to fail is that your model consists only of faces and it does not contain any volume bodies (“solids”) what you can see in the upload log:
I’ve seen this often that IGES exporters of different CAD systems do behave like that which is why generally I always recommend using STEP format to upload models to SimScale which turns out to be more robust. You should see that the STEP model then contains solids which will be easy to mesh and simulate then.
BEst,
David
