'test t' simulation project by aanderson
I created a new simulation project called 'test t':
sdfggr
Hi @aanderson
Its an interesting geometry you had uploaded.
I have done a quick basic Static Stress Analysis of the frame assembly using “Bonded Contacts” and " Nodal Loads".
I found an issue with the original CAD you uploaded. It had a free shell surface inside the solid .
So, I just deleted it in a CAD software and re-uploaded it. Just used Auto-tet mesh with moderate fineness ( for Solid-Mechanics only Tet-meshes are compatible) :
You can view and copy the complete project from the link below to see how its done"
https://www.simscale.com/projects/Ali_Arafat/test_t
Here is a screenshot of the displacement result
I hope this would be of help.
Ali
P.S You can Tag me using @Ali_Arafat so that I get notified about your reply.
