'test project 06' simulation project by ekistanov
I created a new simulation project called 'test project 06':
educational
Hi @ekistanov,
I saw that the Meshing process failed for your CAD model. What file type is your model? IGES?
Could you try defeaturing your model and reuploading it as a STEP file?
Hello, Jousef!
I've got it. STEP filr works great, but it seems like i have some problems with parts connections between them. Could you guide me for some educational video or manual about it?
Thank you in advance!
Hi @ekistanov,
you are probably referring to Bonded Contacts. This post might also help you here.
Let me know if that is what you meant.
Hi, Jousef! Yes it’s what i meant. Thank you, that helps a lot.
