I am encountering errors when attempting to use the surface splitting operation on my stl geometry. When I break up the stl into distinct parts in catia and then split the surfaces in simscale, it works fine, but when i try to run surface splitting on the single, grouped stl geometry, it fails. As i understand it, simscale cant run simulation on multiple geometries together, so I need to get the grouped stl to split. Any help would be greatly appreciated.
its also not showing the geometry in this instance for some reason
What you can do is to split each component individually what you have done and then merge all parts with a script which can be found here: Merge Script for STL.
An easier option would be to simply split everything inside your CAD software and then upload it to the platform - the way you did it on our platform does not work as we have no merging tool integrated (yet ). Splitting with the split tool is sometimes not the best thing to do and as mentioned I would do it inside CATIA.
