'SupportWall' simulation project by pumuckl007
I created a new simulation project called 'SupportWall':
Wall Of the Transmission
Hi @pumuckl007!
Very nice simulation! Do you have a page where we can have a look at your project as you talking of a transmission. Would love to include this amazing project with some more information into the project spotlight! :slight_smile:
Let us know how things go! All the best!
Hello Jousef,
I do not have a page that outlines the project but I can do my best to give a description of it here.
This simulation is part of a transmission which can be found here: https://cad.onshape.com/documents/86fffa5e35544131f79278c4/w/783ba8745fe2f745e99e30d7/e/ca928e950240a706516087b2
I plan to mount two of these transmission to the bottom of a plate of wood on which there will be an 8-bit computer which I have modified to allow for control of the motors.
The third wheel will just be dragged behind the other two.
While using SimScale I was able to reduce the 3D print times by 1/3rd. At first I was using a 1cm thick outside wall, but after running a simulation with a 0.5cm wall I realize that would be more than enough.
In addition to this simulation there are two other parts that I have simulated. A large and small wheel to make sure that they would be strong enough. Again I was able to shave off about a third of my printing time by removing excess material.
I hope this helps and I would be happy to answer any other questions you might have.
-Pumuckl007
That is an amazing project @pumuckl007 - love that you use SimScale for it :slight_smile:
I would really love to see the outcome of that! I am planning to put your project into our dedicated section for amazing projects which will also promote your project and shows people what you can achieve with cloud-based tools like Onshape and SimScale.
I will send you a private message about the project spotlight to discuss this in more detail :+1:
