'Split AC HT' simulation project by anand_sudhi
I created a new simulation project called 'Split AC HT':
The performance of a split air-conditioner in a domestic setting
Can you tell me how to find volumetric flow rate?
Hi @kmedisetty!
The Result Control item Area integral gives the average velocity and if you multiply this with area you will get the flow rate. If you are using the offline version of Paraview’s integrate variables filter gives the values directly.
Hope that helps!
