'SplinedTorqueArmAndAxle(via freeCAD & IGES)' simulation project by mhere
I created a new simulation project called 'SplinedTorqueArmAndAxle(via freeCAD & IGES)':
IGES format -- as if it'll help
Hi @mhere,
seems like you tried to upload an initial STL file as IGES. Unfortunately your IGES file did not contain any solid information and was exported as just a set of single faces.
I downloaded your file, stitched the faces and created the solids using Salome. You can find the project with the uploaded CAD here: https://www.simscale.com/projects/rszoeke/splinedtorquearmandaxle-via_freecad_-_iges-/
I quickly tested meshing and it worked.
Richard
