I have a bellow i have solved by using solid element but i liked to solve by using shell element , I don’t know i have solved properly using shell
Boundary condition’s are
1.Both the end’s fixed
2. inner side pressure 1MPa
Same Boundary condition if i solve for cylinder that’s working for bellow it’s not working
Thanks for advanced reply
Regards
Venkat R
Hello @venkatesan,
Currently Simscale does not support shell elements. I believe they are currently working on this but their is no time frame as to when it will be implemented in Simscale.
Christopher
Thanks @Cristopher
Is there any other chance to solve the same problem using shell element because my geometry thickness is very less compared to length
HI @venkatesan,
I usually solve problems like this with a fine mesh and second order elements. It makes a fairly simple problem very large but that is what is needed currently on the Simscale platform.
Christopher
Hi @venkatesan!
Since you need to only apply pressure inside, your case will be symmetric. Therefore, you can only take quarter of your case which will reduce mesh size and thus computation time.
Ahmed
Thanks @ahmedhussain18
I will try with symmetry
