I am doing a simulation set-up to study the effects of having a supply plenum in a server room.
Could someone help me understand if I have set up the physics of the problem correctly.
I have an inlet velocity from the CRAC units into the plenum directly, I also have a pressure of 0Pa for the inlet grille make the fluid flow in the correct direction. Not sure if the fluid is then flowing from the grille into the servers then back to the top of the CRAC units.
link to project:SimScale
Please could someone help.
