I designed a pedal train made of wood since I had some spare wood laying around. I wanted to simulate if it was going to break or have any issues if i actually applied any force to it before I go ahead and build the thing. I wanted to simulate 200 lb/in^2 of pressure on each of the four upward facing planks but I can’t seem to get my simulation to run. I’m getting the error "The solution matrix is not factorizable. This might be caused by an unconstrained rigid body motion or by over constrained degrees of freedom due to multiple linear relations at at least one node. This is my first time using the platform so I’m not sure what i’m doing wrong
Hi!
Make sure to also post your project link (the URL) otherwise we won’t be able to check what is going on for sure.
In any case, this documentation page contains the usual troubleshooting practices for this error.
