hi I can not simulate this project always gives me the same error: “Maximum number of iterations exceeded when calculating temperature from a thermodynamic potential. This may be caused by low-quality mesh producing unrealistic pressure in a few cells or inappropriate boundary conditions, fluid properties or time step. Inspect fields for large values in the last time step”. I tried to adjust the mass flow of the elements but still the same error. the mesh I can not increase the fineness because it does not create the mesh. please someone to give me a hand because I’m losing hope. here is the link of my project:
“https://www.simscale.com/workbench/?pid=7074487650232377579&mi=spec%3Aefff1925-4b16-4898-8877-99dfb25ec9bb%2Cservice%3ASIMULATION%2Cstrategy%3A443”
Hello matyfalcone
thanks for reaching out to us.
From what I can see there is a big difference in the individual temperatures.
What I would suggest is to use an initial condition for the housing in order to reduce the temperature difference between these two.
thanks for your reply but i put her the two temperatures of the two fluids so she is telling me that i have to increase the initial global temperature.
