Setting gravity for convection - solved
Quick question. Where do you set the magnitude and direction of gravity for a passive convection simulation? The documentation says it can be set in the model parameters, but I can’t see it.
I’m looking at the heat flow in a rotating tyre, and the g-force will be much higher.
Thanks for your help.
Hey @RichMacf,
did you mean this ?
Hi @Kai_himself. Many thanks, should have seen it myself!
