SimScale CAE Forum
Seismic analysis
Hi folks
I’m trying to perform a Time-History analysis, using a Ground Motion Record of a real earthquake for the input displacement.
Someone has experience with this type of analysis?
I always find an error, probably on the definition of the seismic input
The LOG file always report an error:
“The x-coordinates of the F_1 function are not strictly increasing!”
Here is the project https://www.simscale.com/projects/dtaffetani/castreccioni_dam/
Hi @dtaffetani,
the problem is that you mixed the column indices for the value (displacement) and parameter (time):
Looking at your file I guess the first column is time the second one the displacement.
Richard
Thanks, you’re right…but it still doesn’t work
I tried also with Linear Elastic material, and I found the same error.
This time the setup is correct, but it reveals that your input data is not clean:
Here you see that some time values are actually duplicated.
Richard
Many Thanks @rszoeke :wink:
@dtaffetani,
I also took a quick look. Interesting setup - what’s the scenario / application you’re analyzing in that project?
David
The analysis try to simulate the behavior of a dam under a seismic load.
The model is a “slice” of the Dam, and in a concrete gravity dam they are usually separated each other.
The mesh also, presents 3 holes that are the inspection galleries of the dam
The best goal is:
  • analyze the crack propagation in the Concrete
  • analyze the sloshing of the water inside the dam
Stay tuned :wink:
