hi all,
I was wondering if it is possible to save a screenshot of the mesh from SimScale? I know i can do it via print screen on my computer and other common methods (but that would screenshot all the dialog boxes etc which would be unnecessary!) but is there a way to do it within the SimScale platform? I only want an image of the mesh and not the supporting dialog boxes (such as the Scene tree, Mesh settings etc).
cheers,
Manan.
Howdy @mananthakkar87,
see the pictures below.
You can find the screenshots at the left side
dear @jousefm, thanks for that suggestion. However, I haven’t run a simulation yet so I do not have any results. Despite that, I still tried your technique ie go into the post-processor with just the mesh. Although I can visualise the mesh, model manipulation is little tricky and not the same as the Mesh creator; since I have not assigned any boundary conditions, I cannot, for example, hide the faces of the bounding box. But this method is surely useful when i have some simulation results.
cheers,
Manan.
Hi @mananthakkar87,
There is in fact a way to hide the faces of the bounding box, it just takes a few steps:
- Select the Mesh in the Post-Processor tab
- Go to the properties panel (middle section), go to mesh regions
- Select the faces you want displayed (ie excluding the bounding box faces)
- set to surface with edges
- Click on the check button in the panel
Before:
After the steps:
Then you can take a screenshot as @jousefm described
Anna
dear @AnnaFless, thank you for that tip. Yes indeed that method does work. Since the post-processing is done in Paraview, maybe its better to download Paraview and do the post-processing locally.
Kind regards,
Manan.
