'RW11.5 Intake Manifold' simulation project by mtellier
I created a new simulation project called 'RW11.5 Intake Manifold':
This is the second attempt at loading the manifold into Simscale. Details: .STEP file Solid body
Hi @PowerUsers_CFD!
Can someone of you guys help @mtellier here and see what might have happened to his simulation? Seems that he needs some help!
Hi @mtellier,
Your geometry has a defect where there is a cap internally. Do remove that and it should run fine. Also you might want to remove uneeded features like the washer or anything that doesn’t concern itself with internal flow.
