'Roller box' simulation project by Gloppen
I created a new simulation project called 'Roller box':
Roller box
Hey @Gloppen!
Nice geometry! :smile: There are two quick things you can do in order to mesh it easily:
  1. Merge all solids in to one what you think will be of same material. You can have a look at this forum post for more info.: Merging solids in Onshape and meshing
  2. You can than follow this video tutorial to create a mesh: https://simscale-2.wistia.com/medias/1rceuszi3e
    First try to create mesh with 2- Coarse refinement level.
  3. You can than follow this project to setup your simulation: https://www.simscale.com/projects/?search=ahmedhussain18
    Focus on bonded contacts which you may also need to define in case you want to bond solids together with different material properties.
Good luck!
-Ahmed (@ahmedhussain18)
