'rocket' simulation project by zzimmerman
I created a new simulation project called 'rocket':
rocket design test
Hi @zzimmerman,
nice model - I assume you’re looking to run a simulation of the airflow around the rocket? For this, you need to generate a mesh of the fluid domain around the rocket. You generated a mesh of the solid region of the rocket. With your mesh, you could not e.g. run a stress analysis of the rocket under external pressure, but not a flow sim.
E.g. take a look at this project (golf ball flow sim): https://www.simscale.com/projects/SamPrabhu/golfball03/
David
