as i mentionned in my first post in the forum, i am an Civil Engineer but beginner in hydrodynamic.
I would like to simulate a river flow on an specific obstacle form.
I tried a simulation, the run was ok but not i expected at all… (I used Hex-dominat parametric)
Anyone could help me?
Which method / step do you recommand?
Thanks a lot!
ps: i’m french so my apologize for my frenglish i’m poor in technical vocabulary in english
Can you provide a project link, please? Depending upon the obstacle, an incompressible flow could be used or a multiphase flow. Better advise could be provided if you provide a link and good description of the problem If it’s a private project you could also share with me.
Hi @LBV so I would say the first thing to be addressed is the geometry itself, these long thin faces tend to cause a low-quality mesh which in turn makes a highly unstable simulation. Was this an STL converted? uploading the original STL might be a solution if so.
Great! So from here you can, under the geometry, do a geometry operation called face split, this will correctly split the faces where there are features. This will allow the inlets and outlets to be selected but have none of the non-feature faces separated.
Hi @LBV, you might have to add some layers in, some good documentation can be found in @jousefm 's simwiki about wall modelling or even CFD masterclass workshop 1, both can be found here in the forums.
